I am in serious need of some guidance! I feel like I am arranging deck chairs on the Titanic! I did a stator and R/R replacement right after I bought my '89 due to charging problems, both were fried (I posted a pic in the gallery to show what a fried stator looks like!) While I was waiting for parts to arrive, I did a bunch more work including coastering and a de-goat. After I got everything back together, and resolved the additional charging problems, yikes, while test riding the bike to observe the voltage, the bike started to run rough, lost power, and I had to keep it throttled up to keep it from stalling. Long story short, back in the garage I noticed leakage and smoke from the rear cylinder manifold. :wow:
I immediately thought of a couple of scenarios, a stuck float, crud in the carbs, and a blown head gasket. I pulled the plugs from both sides of the rear cylinder to begin to confirm what I was thinking, and they were both wet. I checked the spark for both, it looked weak to me initially, but I checked them against the plugs in the front cylinder, that looked absolutely normal (not fouled), and the spark looked the same. I drained the carbs and it came out absolutely clean (I have been using Seafoam since I bought the bike). I did not notice if the amount of gas was the same from each carb; I just realized that I didn't check that. I was going to try to "burp" the carbs (I think that was the term used describe turning off the petcock a couple of times to try and clear gunk out of the carbs) just in case the float was gunked up, and then I noticed an additional symptom, the bike never stopped running when I shut the petcock off!!
I did some research on the forum and found a few references to leakage and vacuum troubles on a de-goated bike, caused by the back pressure differential, resulting in similar behavior to what I was seeing. So assuming that the de-goat was part of the problem, I re-goated. I also drained the oil and there was gas in the crankcase, which kind of confirms the free flowing gas due to a vacuum issue scenario. I checked the air filters and the vent hose to the right ear; all fine, and dry. All of the boots on the carbs seem to be in place. No additional leakage around the carbs that I can see.
Okay, I am not sure what to do at this point! I am very new to wrenching and I am feeling a bit lost in the woods. What do I need to do? How do I clear the rear cylinders? Do I need to replace the plugs that were fouled? Can this still be a blown head gasket, or a problem with the rings? How do I get all of the gas out of the crankcase? I am chasing a red herring, and the problem(s) are really elsewhere? I could really use some advice!! Sorry for the long post. Thanks.
