21 - 29 of 29 Posts
Discussion Starter #21
I can see it through the sight glass oil looks fresh. But It looks like its above the "H" which I wanna assume is "high"
Yes that’s the high mark. Folks on here say that you should see a bubble at the top. Sounds like your over-filled a bit. If the bike leaks much worse after it’s running that’s a good indicator because that means it’s getting pushed out by the pressure. It took me a week to figure out what was going on. I’d see a small spot outside my house then take a short ride and leave a golf ball sized spot wherever I went.
Looks like some JB Weld on a bolt and case seam.
Think that black hose is probably from the coolant tank overflow. Does it have antifreeze in it?
it's hard to tell how much coolant is actually in there but appears low. What coolant goes in there?
50/50 mix of antifreeze/distilled water.
Discussion Starter #29
Let the bike sit out for a few days with an oil catch can. Drained the radiator added fresh green coolant waited for a few minutes let it get to where I could ride without choke on idle didn't go above 2,000 rpms after riding no leaks or oil spitting out I think we are okay!
21 - 29 of 29 Posts
