1 - 6 of 6 Posts
What's the typical lifespan of the bearings? How do you know if they're bad?
I swapped wheels from my old bike (27k) to take advantage of its newer tire.
When I'm riding, I can feel a vibration in the handlebars that goes away when I'm riding straight, but comes back whenever I turn. It reminds me of a bad bearing in a car wheel. Am I imagining things? Could it be from the pads not yet worn into the different rotors?
Shouldn't be the brakes unless you only feel it when applying the brakes, or maybe if the brakes were sticking.
Any irregular spots on the tire tread? I guess it didn't do this on the other bike?
Discussion Starter #6
I don't recall it doing that on my other bike, but I can't say for sure that it didn't. I know it didn't do that on the new wheel/old tire combo that came with the bike. Only when I switched to the old wheel/new tire combo from my old bike. The tread looks even. It's not enough of a lean angle to be the result of using a different area of the tire. When I'm talking "turns", I should clarify that I'm talking about gently shifting lane positions rather than a true "turn". It's a subtle vibration too, but I'm being very sensitive as I have a trip coming up in 3 weeks. I want to make sure everything is A OK before rolling out.
I suggested the brakes, as I've had a car with a warped rotor that you would feel whenever applying the brakes, or during hard cornering. I guess in that car, there was enough flex in the assembly that the pad would drag slightly in a corner? I'm not sure what caused it in that car.
My cousin has a Triumph with rubber bushing mounted handle bars to reduce vibration. (Incidentally, the handle bars shake from the wind and the rear view mirrors are useless at highway speeds!) I was just thinking that the vibration I am feeling would be completely eliminated by this mounting system and I would be none-the-wiser. :| Not sure how I feel about that.
Thanks Knifemaker, I'll try that out.
Is there any way to tag someone in a post to get their input? I'd love to hear from some of the seriously high milage club. I know Jerry had over 100k on his bike when it finally quit. If bearings fail, they'd know how often! 27K seems low to be having issues.
1 - 6 of 6 Posts
