1 - 5 of 5 Posts
Need to replace the blinker/running light on my 1999...3 wire
The bike has
Gray
Blue
Brown with stripe
So which is the running , ground and flasher wire?
Brown w/ (yellow?) stripe is ground
Grey is blinker
Blue is running
If ya have a volt meter, you can easily confirm this.
Here is the wiring diagram. It's a little large, but easier to read that way...
I just got done putting a buzzer on for the turn signals and this is what I found out.
black/white = ground
blue = running lights
gray = turn signal
At less that is how mine is. To check for sure turn the key on, turn signal on and unplug the gray wire, the running should stay on and turn should stop.
:hitanykey Well, I should have read Buzzin's post closer.:doh:
CWO3 Navy (Retired)
I'm sure the pictue will clear it up for you - have a 12-pack first so it makes sense.
Just did this myself, it's really is easy.
1 - 5 of 5 Posts
