1 - 5 of 5 Posts
Looking for some suggestions for a small problem I'm having. Just changed out all 4 turn signal bulbs to led bulbs also replacing the factory flashing relay with a JL-02 (EP34) relay (see link below). With the new relay, the flash speed is normal and the back turn signals work just fine. The fronts however, illuminate but do not flash. If I install a halogen bulb into the front turn signals, it will rapidly flash when the turn signal is switched on.
3 Pin CF13 JL-02 EP34 Car Flasher Relay Fix LED Light Hyper Blink Flash No Flash | eBay
Any idea or suggestions on how to resolve this?
Are the LEDs dual (two contacts on the base) or single (one contact on the base) intensity? Front should be dual intensity.
1 - 5 of 5 Posts
