An impact driver does help with breaking the threadlocker, but it's a tool most don't keep around anymore. Was a 'must have' to remove phillips head crankcase screws. They aren't usually expensive, the impact driver is designed to turn the screw when the driver is struck with a hammer. It's not that the screws are extremely tight, they are just glued with threadlocker. You also have to be wary of stripping out the heads, be sure the hex wrench/bit fits tight.
Releasing the springs won't help with breaking the threadlocker at the bottom. After I loosened the top caps with the hammer/socket, I used the socket/extension to hold the cap down with one hand and popped the clip out with a small screwdriver. The springs will come up about 4-6" when released, so not a lot of tension, but some.
