1 - 7 of 7 Posts
Yearround Rider
Discussion Starter · #1 ·
Well, finally at 35K. I have the pads, and dismounted the left caliper, but cant figure how to get the bigger (inside) pad out. The one with the two holes that track on the two stems. The trusty Service Manual says "push the caliper holder to the piston side, and then remove the pads." Well, the small one next to the piston lifts out easily, but the other is prevented by the two stems.
I think I'm just missing something simple. Should the stems move in the housing? Is there a simple pushback procedure?
All is back to OK but it's gnawing. Help appreciated as in times past.
Schooner
(More replies will be coming.....)
I vaguely remember doing mine and kind of leaning and twisting the pad (as much as it will twist) and getting it off of one post first, and then the other.
Somewhere in this forum, somebody wrote up a better detailed description of getting it out.
There is no special tool or anything though, it does pop out, just not as easy at it seems it should at first, but it doesn't take more than about 5 minutes either.
Sorry I'm not more help here, but I just don't remember the details all that well.
The Professor
You have to squeeze the mount bracket as tight as you can toward the piston. It will come out and go back in. :smiley_th
JUst had this fight ,Push the part the pad with the holes in is on all the way inbut keep the pads near the end of the pins,tilt the pad in toward the center of the caliper while holding the floating part with the pins in and the pad will slip right out,if I did not explain that well enough,here it worded a little different is tilt the part that points toward the center of the wheel (opposite of where the pins go through towards the center of the caliper and it will slip off the pins, hard to explain but once you do it once it is a puzzle you won't have to work again,hope this was some help and didn't just confuse you worse
Yearround Rider
Discussion Starter · #5 ·
Thanks, VN750. for the assistances. Those plus a couple of comments from other sources got the job done today: "the caliper holder without the rubber friction boot moves easier"; and the "end of a 1/4" short extension with a socket on it to push that one in far enuff (sic.)." Also recommend a flat screwdriver for various wedging needs, and teflon spray. Where did they come up with that non-trivial, non-Manualed design? Again, many thanks.
Schooner
Thanks, VN750. for the assistances. Those plus a couple of comments from other sources got the job done today: "the caliper holder without the rubber friction boot moves easier"; and the "end of a 1/4" short extension with a socket on it to push that one in far enuff (sic.)." Also recommend a flat screwdriver for various wedging needs, and teflon spray. Where did they come up with that non-trivial, non-Manualed design? Again, many thanks. Schooner
Can someone explain to me how to get the pad which pins go thorough both sides.. Rubber both sides one comes out of the hole in the back and other doesn't. Those rubber needs to be replace I think they sell replacements of them.then.. If I understood correctly I have to tilt the pad as much as I can to get it out of the pins is that correct. And has no other way holding pins to the caliper body to take it out? My email is below please send me info if any one who might want to help me. Many thanks [email protected]
1) slightly compress the caliper piston, a c-clamp is best but even a screwdriver will work, you just need to be careful
2) remove the caliper bolts
3) remove the caliper
4a) note the position of the clip in case it falls out, you'll know how to replace it
4b) slide the pad out of the caliper, it should pop out of the clips (you can pry the pad out but do not bend the clips or the pads won't fit)
1 - 7 of 7 Posts
