Sorry to hear about your problem. It sounds like you replaced the R/R with a stock setup and not a mosfet, but either way I suggest you check the stator output. The procedure is simple and outlined in several places on the forum. Hopefully you have a tester that can read both DC and AC volts. Did you move the R/R from the stock position under the battery and what brand of regulator/rectifier did you get? Also if you have a tester, you may want to follow the procedure and check it. If you have any questions check for the answers here. Almost every problem has been dealt with here at one time or another and many answers to problems have been posted already. Hopefully you have a manual also, either downloaded or paper. You will need one. Good luck.
