I was working on the bike (2004 VN750) which had locked up engine, from what I can tell was already split in half before me and reassembled bacn with a worn crankshaft, which caused piston go nuts and damage itself and the bore, but thats another story.
Got replacement parts for that problem, but as I was testing-assembling it back I've noticed that there is a friction between shift forks and output shaft gear bodies. I can move input shaft freely, but output shaft is not so free to move (rotating it in neutral).
Upon inspection I can see exactly where thus happens (shift works are rubbing).
Also, inspected the housing on the left crankcase for the shift forks rod, and I see it was bent back and the rod itself has some play. You can see it can wiggles to the left, however when I put right crankcase on I make it straight as it supposed to be, which is to the right, and I am not sure if this play affect the positioning of the forks.
Few questions here:
1. How reliable it is to proceed with assembly this way? Is there a chance this will break-in a bit and will cause no trouble in a not-so-long future?
2. If it's not safe, maybe you have any creative ideas how to repair that? I was thinking JB Weld or some kind of cold welding compound to partially fill into the housing and drilling/sanding it to the necessary form.
P.S. This initially was a parts bike which I got for cheap, but got a chance to make it run again, so I might not care if things won't be ideal but still work.
Few questions here:
