1 - 3 of 3 Posts
Has anyone ever modded the left frame to make the stator more accessible, meaning cutting out the tube and having inserts made that would slide into the cut off tube ends and welded in place with dual bolts, sort of like the right side, what seems to be the main stator failure causes, we had a regulator we installed last year go out on a ride, My own fault, I rewired everything to run directly to the battery, but my son opted for the cheaper route a new reg off ebay. it gave out in 9 months, ended up putting on a factory part off a Yamaha 600, worked great and charges better than it ever did before,
thanks
looked very doable considering the engine is bolted in between the frame adding support.
1 - 3 of 3 Posts
