1 - 10 of 10 Posts
Anyone out there got a fan switch (from bottom right hand corner of radiator if in front of bike). Used is ok as long as it is functional.
Patriot Guard Rider
I'll check for you when I get home from work.
10-4 Thank you : )
Hey Stones, it is conventional to describe left and right side of the bike as though you are sitting on it.
Just easier to avoid confusion that way if everybody uses the same terminology.
Good luck with the hunt. :smiley_th
romeobravo172
You can very easily bypass that switch, install a toggle or whatever and still ride till you find a replacement. Ck out previous post from 350Earnie2.
Discussion Starter #6
Sorry about the direction confusion I'll keep that in mind :doh: I thought about doing a bypass but the switch is broken corroded and leaking coolant so I'd need to find a way to plug the hole.
Patriot Guard Rider
I have the fan switch removed but do not know if it works or not.
Discussion Starter #8
So I took the advice and put in the best toggle switch I could find- 6.00 at oreilly's and now I'm childishly hopeing missles launch the next time my fan needs to be turned on :smiley_th
to plug the hole where the fan switch goes use a short bolt with threads that are 10mm by 1.25 I'm in the process of finding a cheap replacement fan switch thru bwd
1 - 10 of 10 Posts
