1 - 3 of 3 Posts
Hey all - had to work on the fan and I noticed the ground cable coming out from under the upper-left fan shroud screw and I don't know where the other end was connected to ( that you previous owner). Any thoughts?
On the fan unit itself, the ground cable is hooked up to the upper left hand bolt (back side); on the bike, I've got the cable bolted to the frame under the lower bolt, left air filter housing.
Thanks Crobins - So I will connect from the screw on the top-left of the Fan Shroud to the bolt in the lower left of the Left Side Ear. Wonderful.
1 - 3 of 3 Posts
