1 - 20 of 49 Posts
I've been having odd issues with the fan not turning on. I get it to work and think its fine then the next day go for a short ride and it doesn't turn on. Today I decided to take the easier route and put in a manual switch. Went to AA and got a metal pre-wired toggle switch 10amp. Tapped in line of the fan sensor to one lead and the other to a black yellow wire that was near by. Turned the bike to the on position and hit the switch and it worked fine. Buttoned up the wires and tried it again still worked. Cleaned up my tools and let the bike warm up sat on the bike to get a feel for the new switch and now nothing it doesn't work. Unplugged the sensor and tried grounding that to the engine and all I hear is a clicking sound near the battery. Ran out of day light to narrow down the sound but I am lost. Any suggestions? Should I have gotten a 20amp switch?
you have a couple of problems... First you have a faulty Fan Relay inside the fuse box. Secondly you tried to bypass the fan relay, but didn't. you need to wire a positive wire to the toggle switch, then from the switch to the fan. Or, if you want to run your switch on the ground side it would look like this:
The Solid lines are the way you have it wired now, the dotted lines shows where you need to splice and re run your wires.
The fan runs off a relay in the fuse box. Could be it's failing. Someone on here has a reference # you can use to replace it (I think).
Looky there, Sparky to the rescue! LOL!
Discussion Starter #4
Maybe I should start looking for a new JB then. But I would like to add in this switch for the future incase it would happen again I won't be stuck. I'm a bit lost looking at your diagram. The top half of the image is how i have it now. Sensor to switch and switch to ground. But your saying I should go sensor to switch and fan to switch? This will keep the stock setup working correctly when i fix the junction box but also allows me to overide the system?
You could bypass the entire system and run fan off battery and use a toggle switch.
Slim, isn't the fan relay replaceable?
PArdon my misunderstanding of the diagram, but what does putting a toggle switch in series with the fan sensor do other then disable the fan when the switch is off and enable it like stock when the switch is on? If you simply add the dotted line wire the fan will always be on wont it?
kenny
kenny
Thats what I was thinking Keny.. but that is how the OP said he had it wired... I drew out the diagram to point out the fault...
I was unclear on how to do it the right way, so I made the fallowing diagram. the toggle can either be on the ground or the hot side. I personally would have it go back to the sensor since the sensor is known to work and would automatically turn the fan off and on at the correct time and also wouldn't allow the fan to run if some one forgot to turn off the switch.
Not as easy as it sounds... you have to very carefully cut open the JB, unsolder the Relay from the circuit board, find the correct relay and re-solder it. once all that is done you have to jb weld the box back together and make sure there are no leaks.
Discussion Starter #8 (Edited)
Ok I am really confused now. This morning I tried splicing in the black/yellow wire of the fan to the toggle switch and it still wouldn't turn on. So right now I have the black/yellow of the fan to the toggle switch and then the other lead of the toggle switch goes to another black yellow wire. I then disconnected the fan ground jumper from the toggle switch and tried touching it with the battery ground and it still didn't turn on. I'm thinking that maybe if the relay is bad I'm not getting any juice on the blue wire?
with that drawing, you are tying battery ground to battery ground through a switch, sorry to be a PITA but I don't see the benefit.
kenny
Discussion Starter #11
What I would like to do and maybe I'm not saying it correctly is to keep the sensor still in place so that it would still function correctly but also have the option of manually turning on the fan. From the sounds of it my JB relay is bad but if that's then how can I get the fan to turn on?
Doesn't the relay in the JB switch the ground to the fan on and off?
I think that was how I remember it, but I don't have the wiring diagram in front of me.
....that's how I know it....providing the JB relay is functioning properly.
The temp sensor on the bottom left corner of the radiator ...when heat activated, turns the fan on via grounding the fan circuit thru the JB Relay. By adding a toggle switch to the wire attached to sensor (switch connected to ground), will allow the fan to be turned on manually, but still only with the Ignition Switch on.
hope this helps
:smiley_th
Write the toggle switch to the sensor then to the ground in the fan. Run a wire from the battery to the positive aside of the fan. The sensor grounds out the relay inside the junction box and since the relay isn't working you aren't getting power back out of the junction box.... Blue write is not a stock color in your harness for the fan.
Discussion Starter #14
I can't make sense of that post. So your saying the blue wire feed from the fan would go to the battery - that I get. But your saying for the switch I'll still keep that to the sensor ground? Or move that to the fan ground?
Discussion Starter #16
Does this bypass the stock setup with the junction box, or allows the stock setup with a working jb to function same with the added option of a manual turn on?
It bypasses the JB and fan switch altogether. It is no different than taking a 9V battery, wiring a switch, a small electric motor, then back to battery. It really is that simple. Only difference between my example and slims instruction is the 10A fuse.
Discussion Starter #20
Put in the new juction box and nothing. When I try to ground out the sensor wire I hear a clicking sound from the juction box I beleive. When I try to ground out the ground on the fan harness nothing. Took my old harness and cut the fan plug off and ran two temp wires to the battery and the fan turned on. What am I over looking?
1 - 20 of 49 Posts
