1 - 3 of 3 Posts
Where does the fan ground wire go to? I had to take the radiator off when doing my stator swap and can't for the life of me remember where the ground wire bolts to.
it should have terminal on it that slips on the sensor/switch that is screwed into the bottom of the radiator.
romeobravo172
I think what you are looking at is that 3+inch black wire with 2 round terminals on it? One end fits to the radiator, the other end goes to the mounting bolt below it. I would assume it helps to ground the rad to frame. Think it is used on the left side.
1 - 3 of 3 Posts
