:doh:I had ran my 95' low on oil and it started to knock. Going down the road with the clutch in it wasnt so bad, but when on the throttle it sounds bad. The knock is inconsistant, and is coming from the rear cylinder. I have pulled the engine to get to the top of the heads. Now that it's out and the top of the heads off I see nothing wrong. The lifters are not stuck and valves look ok. I had drained the oil before pulling the engine and there where no metal shavings or pieces of bearings. I'm was going to pull the cams today, can anyone shed light on my situation? Is there something I'm missing and is there a certain way to pull the cams? Any Help would be greatly appreciated.
Thanks.
Thanks.
