1 - 8 of 8 Posts
Would really be thankful for some sugestions, my head light is quite dim and kill switch won't work. When I hit the kill switch the light gets a little brighter. What should I look for? Grounding problem? Thanks for any info!
HAWK
Sounds like you have a loose or Dirty ground.
I go with the ground also
Discussion Starter #4
Thanks for the reply, That's what I was leaning toward. Day off tomarrow, will have time to check it out. Thanks again
Samson
That seems kinda strange. Does the bike seem to run OK, other than the dim light? And is it ALL the lights that get brighter?
Discussion Starter #6
Yes the bike runs fine. I found the problem with the light, bad wire and bad bulb. But kill switch still dose not work. I have yet to find the cause. Any ideas? Maybe a bad switch?
Thanks!
Samson
The contacts on the switch might be dirty.you can pull the switch apart and clean the contacts and see if that works.
1 - 8 of 8 Posts
