1 - 15 of 15 Posts
okay so heres My new problem
mybike is running rough couging backfiring. only started after repacing plugs
in the past week I have
repaired ignition switch
re routed gas lline
re routed hose to right ear box
new plugs
new throttle cables
re routed choke cable
ran lots of seafoam through
bike ran like a top for 2 miles then quickly went downhilll from there
it sputters surges back fires. tried wd 40 for air leaks seems like problem is in rear cylinder. when we reomove one of the rear plugs the bike settles down. but we can remove either on on the rear. the bike runs steadier.
First .. I would recheck your gap on your plugs...then check for a pinched hose on the carbs and breathing system....have you turned your fuel/air screws out to 2 1/2 turns?.. also check your pulg wires.. could be grounding out someplace....it may be a simple case of needing to do the "marbeling" trick.
planning on doing all those things today. Its been 100 here most of week and hot is no fun earning to work on a bike. it seems like everytime we fix something something else is wrong. we will run out of things to fix soon..I hope
Man I had the same issues with rebuilding my "parts bike"...1 thing led to another..but she is running like mad now... old bikes sitting for a long time, slitly poor design in some areas and wanting to custom things.. makes for a long jurney but its worth it...where are you located at?..its been hitting close to 100 here in Oklahoma too.. if I dont work on the bike butt crack early in the morning it dosnt get fixed..LOL
living in alabama
Yes when the bike runs well it realy runs well
this is My first used bike. I remember now why I always bought new bikes before.
but this ha been an interesting Journey so far
living in alabama
East Alabama by any chance? Lance, a member here, has probably worked on, repaired and resurrected more of these bikes than anyone. If you can't get it fixed yourself, he is a great alternative and his rates are very reasonable. He's in the Atlanta area.
You know, this may seem strange, but I bought a project bike a couple of years ago that behaved somewhat similarly to what you've described in previous threads (surge-and-die behavior or just crazy-scary surging) and the problem was that the surge tank itself had a small crack in it. I was unable to find it until I was pulling the engine and doing some other things to the bike, but it turned out to be a hairline crack along a seam.
Failing that, double-check where your rear carb boot goes into the tank - there might be a leak there, or a crack in that boot (or in the tank where the boot gets inserted).
X2,,,, parts bike eques.. take it all apart.. be picky about how you put it all back together.. check everything make it run.. then do mods.
Discussion Starter #9
we removed the after market inline fuel filters..replaced fuel lines. replaced spark wires on rear cylinder. routed vent hose under seat. adjusted air screw. ran like a top. drove 1 mile same problems sputtering back fire and loss of power.. when i tried to turn off and back on voltage was low and headlight would not come on,
Those inline filters may have been on there to keep crud in the tank from reaching carbs.
Discussion Starter #11
they madde fuel lines kink because of lack of space
also... in line filter?.. that was an add on!...still thinking its a vacume line though and marbeling will help as well.... power sucking emitions blow!....but also.. you said you added seafoam...well you could be gettign thru the "carbs butt ugly dirty" phase too...sucking a bit of ugly and burning it as you go... I know I seafoamed the crap out of mine when I got it... it smoked, sputtered, bitched, called me dirty names.. and finaly cleaned itself out and ran like new after about a tnak full...just saying... she is a quirky chick and you got to rub her right sometimes.
Discussion Starter #14
the inline fiters kept kinking the fuel lines
we also tried marbing and the bike ran terriby
The Reanimater
Sounds like you could be flooding the cyl or your having a miss fire.
I remember someone here having unplugged the coil & got the wires crossed
(the red & green) But can't remember what problem it made & fixed.
1 - 15 of 15 Posts
