1 - 7 of 7 Posts
Bandito
I have the 1 emgo filter hooked up to the crank case, thats fine, the other emgo filter, do I run a line from the T on the top vacuum lines to the the 2nd emgo and cap the right vaccum valve or do I run the line from the vacuum valve on the side of the right carb and leave the T open and unfiltered? And how did you fit the smaller vent lines to the emgo?
The Professor
Cap the rear carb vacuum nipple, use 5/16 fuel hose from the carb vents at the T and connect to the emgo filter
Bandito
What do you use to cap the right side carb nipple?
I could not find a single picture of a bike with an ear shave showing a close up of the right side carb I looked through hundreds of photo's, all the pics are always of the left carb, when I get this done I am gonna take a picture.
The Professor
7/32 vacuum cap, available @ any auto parts store. :smiley_th
Bandito
Thanks for the help lance!
I'll take some more pics tonight but here is a quick mock up. The emgo filter is connected but out of site.
If you still have any of the hundreds of feet of rubber vacuum hose left from removing emissions crap, you might want to cut off a piece of that, screw a screw in one end and stick it up under the tank, and put the other end on the carb for a plug. I've have several of those rubber vacuum caps rot to pieces from exposure to the sun, in just a few weeks. The hose doesn't do that. Jerry.
1 - 7 of 7 Posts
