1 - 5 of 5 Posts
Discussion Starter · #1 ·
Hey gang...
Last September I bought a Dyna2000 ignition module when Dyna had a closeout for $150.00. Well, it quit on me today, almost left me stranded. I know a lot of you will remember Bulldog having the same problem and how he went thru a PITA to get Dyna to take care of it. We shall see how it goes for me. It was his wise words, however, that got me to pack the OEM unit whenever I went out. Thanks!! Bulldog!
For those of you who have one of these...here are the symptoms to look for..
1. Hard starting...out of nowhere. Yesterday, started fine multiple times during my 200mi jaunt. Today, took me 5-6 tries initially. The engine starts, but immediately dies, unless you give it gas immediately. Not good on the initial start up of the day. I thought I had a choke problem, but got her going...
2. When pulling off the line, you might notice some minor stumbling...very minor. Happened twice today in ~5mi. I thought I had let go of the throttle or some slop in the cable...
3. Yesterday, I noticed brief hesitation on the throttle once, only once, while making a passing move from 60mph. Now I gotta tell ya, the Vulc NEVER hesitates! :) So I'm thinking Seafoam, right?? Happened toward the end of the ride...
4. Today, the major indicators. After the hard starting and ~10mi, lost power to one cylinder, no throttle response past 3k, tach going crazy. If you let off the throttle, the revs go immediately to zero.
I went ~1mi like this, turned around, went another mile, and pulled over. I hesitated to shut her down bc I was not sure I could restart, but in those 2mi I thought abt everything it could be, then recounted the Bulldog's experience. It took only 5min to disconnect my Dyna2000 and reconnect the OEM unit from my pack. Voila'!!! All systems go for the next 150mi.
Bulldog, I owe you a 12pak, bud....name your brand!
Anyway...hope this helps someone out there. I will post my experience w/ Dyna when I give them a call tomorrow...
Growling at the World...
I'm beginning to have those other symptoms. Hard acceleration and stalling when taking off.
This is really pissing me off!!! My OEM is wrapped in bubble wrap in my saddle bag and I'm hoping I don't have to use it...
jm1515 said:
Hey gang...
Word of advice. I called them when I got my unit because I was having problems getting it to work. It wasn't their fault, I had accidently grounded a wire. Fixed the wire, problem gone. But their unit wouldn't work at all with the problem, while with my OEM unit at least one cylinder would fire.
Anyway, go through your entire ignition system, plugs, coils, stator and make sure it is all up to the settings in the service manual. Based on my conversation with them, they won't do squat unless you have verified the problem isn't somewhere else.
They won't do squat anyway. Dynatek is the WORST aftermarket accessories company out there... What is it about California companies???
Discussion Starter · #5 ·
Mike..thanks for the advice.
I guess I will check the coils....stator is new, RR is new, Iridium plugs cleaned & gapped 3months ago, wiring looks great. It's not possible to connect wrong...two completely different, polarized plugs.
I don't blame any company for wanting to be sure it's not their product at fault when it's in a dependent system, but ISTM that when you replace a component on the fly w/ another component and everything works as it should...you've located the source of the problem, esp if others have had the same experience. Stay tuned....
1 - 5 of 5 Posts
