1 - 10 of 10 Posts
knees in the breeze!!!
well when i do my winter refit i plan on moving the turn sigs down on the forks and useing aftermarket ears to mount the headlight
the new ears have round holes in them
so i plan on mounting driving lights on each side of the headlight
my question for those of you who have xtra lights is where and how did you put in your switch????
i even thought about useing the run/kill switch for this as i dont use it for anything else
opinions???
If only it had 6th gear..
I ran auxilary lights without a switch by tapping into the running light circuit so they go off with the key. They're LED so they don't draw much. My thoughts on using your run/kill to control lights: Although I don't use mine either (pretty much always turn off with key) I think its a good thing to have an engine kill switch right near your thumb just in case. Even if you only use it once, and that once saves your life, it's worth it. Weird stuff can happen man and you never know if you'll have to shut it down fast. That's why its there. I don't think you should ditch it. Just my opinion for what it's worth. For handlebar switches there's got to be some choices out there. Or maybe mount one up on one of the neck covers in front of the tank.
do you haveany pics of those lights and how do they show up at night ??
I'll try and take a couple of picture. They show up even with the spray of the headlight and I think they're as bright as other fog/auxiliary lights I've had on my cars before. I got them more for being seen than for seeing but I'm happy with the added
Glow they give off. Got them from www.superbrightleds.com and I'll check that address and update it if I'm wrong.
I put my switch into the plastic collar in front of the fuel tank. I used a toggle that lights up purple and I can see it on a sunny day. Although I had to cut the handle down on the switch I still have an issue when I turn the handlebars full left. So pick the location carefully but that's a good spot because there is room under for the body of the switch. The other option is to use a relay so the lights only go on when you run the motor and the headlight is on. Don't use your kill switch, it's a good thing to have.
I used a relay and activated the relay off of the high beam lead. I supplied the lights right off of the battery. I also had an on and off switch to cut the lights off any time.
Here's a couple of pics I got while yhe hurricane let up a bit :)
2FAS4U
I used a surface mount switch.
It attaches with double sided tape under the gas tank.
Picked it up at a local parts store.
1 - 10 of 10 Posts
