1 - 11 of 11 Posts
Does drilling holes in the clutch basket always cure the coffee grinder clutch problem?
I want to end up doing the mod, since it was done at Kawa as a fix anyways, but I am rarely affected by it. If I hear the noise, then it means I failed to let my bike warm up to proper operating temperature. :p
Related question: Does this just solve the noise or does it also help the grabbiness of the clutch?
Ok Stewart, sounds like your ready to try it. Report back on if it works or not!
Discussion Starter #7
Thanks for the info, everyone. And thanks for the re-post of the diagram, Chris. I want to do it, but can't do it on my own. I've never messed with a clutch before.
I've always used Rotella 5w40 synthetic oil... and have never had a problem. The synthetic is a little thinner at room temperature, so it's already kind of 'warmed up'. :)
Discussion Starter #9
That ^ is interesting. I was wondering why more folks didn't use 5-40 as it would seem to make sense given the clutch problem. Too bad I just changed my oil (10-40 synthetic).
Well not everyone using 5-40 reports the same thing. Why don't you ask n2 if he has no problems with clutch grab on his bike when it's 34 degrees out? ;)
It is true certain motor oils have worked well to nullify the coffee grinder symptom for some owners..... But not all.
I don't ride my bike when it's 34º outside! The coldest I've gotten is in the 40's... and I keep my bike in a basement garage that stays warm. :)
However, synthetic oil is thinner at room/cold temperatures than conventional oil... and 5W flows even better when cold. 5W40 Rotella Synthetic (diesel) oil would be the first thing I would try if I had a bike with a grabby clutch... Quick, cheap and easy! :)
Good Luck!
1 - 11 of 11 Posts
