1 - 10 of 10 Posts
My Clymers manual says clearly DOT 3 for brake fluid.
The top of my master cylinder on my 2004 clearly says DOT 4
Which one do I put in??
I use DOT 4 because it absorbs less moisture and has a higher boiling point. Either could be used.
DOT 4 is just a synthetic version of DOT 3. It will last longer before turning into goo, and will have a higher boiling point, which probably doesn't really mean much on these bikes.
Whichever you use, it should be flushed out and changed every 2-3 years. It's also smart to do it on cars every so many years as well, as brake fluid absorbs moisture, and causes calipers to rust/freeze over time, and flushing the fluid helps keep this from happening.
Investing in a set of speedbleeders makes it easy.
http://www.speedbleeder.com/
Good Luck!
Mechanics will verify it is safe to go up or down one DOT #. Personally, I'd stay with DOT4.
NOT ENTIRELY TRUE.
In the case of DOT 3 and 4... Yes.
However, DOT 5 is silicone based, and is NOT compatible with DOT 3 or 4.
Patriot Guard Rider
I'd go with what is written on the MC itself. Clymers are out of date in some ways..and do have typos.
Dot 4 is better anyway...............
I agree with KM!
I use the DOT 4.
1 - 10 of 10 Posts
