1 - 2 of 2 Posts
Hi everyone,
I did something similar to my Mean Streak, so I though I would do the same thing to the 750. I took the inner liner of the dash with the wires and lights, pulled out the lights and drilled six 10mm holes. I covered the area with a carbon fiber film and then put in the representative LED lights.
Due to the back side of the cover I had to use a metal plate so that it would hold up the back of the LED bulbs and still be thin enough to get a small nut onto each LED. Trying to get everything set up I scratched a couple of the LED's, so I may replace those in the future.
Here is the link I used to get the LED's (10mm) - https://m.ebay.com/itm/12V-36V-8-16mm-LED-Dash-Panel-Warning-Pilot-Light-Indicator-Lamp-Car-Boat-Truck/382250071732?hash=item58ffe136b4:m:mpFZksP0E4_daosIYUwH10Q&fbclid=IwAR1pjt3_NXagSFWnTEA3KNcVHI_3RyXSBdEJktaSx79oX8j8DGg1nGsx4Iw
Hopefully I can get this set up by next weekend.
Cheers,
JT
Retired USAF (IYAAYAS)
I guess I will need to see the finished product to get a good mind's-eye idea of what you're accomplishing/attempting.
1 - 2 of 2 Posts
