1 - 2 of 2 Posts
As some of you know I am in the middle of the slow rebuild of my 92. Stator should be in in a few days from Tim. While waiting for that I have decided to replace the dampers. I got the flywheel off and the gear. Where are these marks I need to look for to put them both back on correctly. Also what are the torq requirements? One last question for the left balance gear which hole in that does the nub of where it bolts to goes into it?
Here you go - balancer is the first one, stator is the second. Looks easy when they're off the engine, but I know it's a little harder once you're trying to reinstall. Just take your time. And make sure the two marks line up exactly. You'll think it's impossible and might throw a few things along the way, but it can be done.:hitanykey
1 - 2 of 2 Posts
