1 - 5 of 5 Posts
Hi! Members!
:confused:Anybody here knows this part that is being sold in eBay?
Is it usefull?
Or it does not work?
Part name:
- Kawasaki VN 750 cc VN750 Vulcan 6 Sigma Custom Carburetor Carb Stage 1-3 Jet Kit
Item number:
230728761100
Price: US$49.50
Seller info:
Member id: 6sigmajetkit
Thanks...
Your looking at a jet kit. It's the internals of the carb. You would not need this or want to use it unless you have modified your intake. ie: ear shave, removing the stock air filters & replacing them with aftermarket pods or such.
It has been disscussed to death that you don't need a jet kit if you keep your stock intake & only change the exhaust.
I found my bike ran a bit lean after installing V&H Cruzer pipes. I did not use a jet kit, which is very expensive. I replaced the main and pilot jets in each carb with the next largest size, as recommended by the late Lance328. It worked perfectly. Got the plugs back to the right color and eliminated a couple of flat spots.
1 - 5 of 5 Posts
