1 - 5 of 5 Posts
Got my V&H Cruzers installed and DAMN!!!!!! They sound SOOOOOO good
But.. As The Knights Who Say Ni so beautifully put...
There is ONE SMALL PROBLEM!!!
I have the F&S Engine Guard. I was not able to put on the right pipe with the guard on, so I removed it, installed the pipe and now i don't think I can get it back on.
Does any one else have this issue?? Will the two fit with one another? Is there a trick to getting it on or am I just missing something.
Or will they just not work together
Any help and pics with your setup would help
Discussion Starter #2
just to fill everyone in, since I seemed to have stumped the forum...
The Cruzers and the F&S Engine Guard WILL fit.
Its a pain n the bo-hunkus but it will fit
V&H Exhaust
I received my new V&H exhaust yesterday and installed them today. Sound good but seem to have excessive backfiring. Have not touched the carbs or the air intakes.
I know I will need to deal with the jets for optimum performance per posts on this forum and on the V&H documentation.
Have you had the same concern? Have you adjusted the jet settings or replaced stock with larger ones?
Discussion Starter #4
check the air mix screw and back it out some. Mine was really lean and I backed mine out a GOOD 4 turns on my stock exhaust to get rid of the popping. I turned it back in afterthe cruzers were put on and just have a bit of backfire from the right side.. just gotta find the right mix
Prob won't have to touch jets, but you'll want to back your AF screws out to 2 1/2 and start from there.
1 - 5 of 5 Posts
