Hello and new to the forum. I recently bought an 94' 750 vulcan with oil leaking out of the clutch cover gasket. So after I installed a new gasket with new fluids and fired it up to find leaking coolant from the dreaded weep hole. ARGH!! Then I drained both coolant and oil again not noticing any mixture of the two will draining. After removing the stubborn impeller and the even more pain in the a$$ mechanical seal Im now inspecting the red seal on the bearing. Notice the small opening at the 4 o'clock position. Is the enough to let coolant through and drip out the weep hole at the bottom?
Second question: The shaft will move back and forth about an 1/8 inch. Is this ok?
