1 - 6 of 6 Posts
Live And Let Live
Changing my clutch today, can anyone please tell me if I need to
use sealant on the new cover gasket ?????
I did work on the stator side and used a spray sealent made by permatex. I sprayed both sides of the gasket. Let it dry and then installed.
No mention in the Clymer manual about using adhesive or sealant on a new gasket for the clutch cover, so I would think you don`t need it, but I have no hands on experience with a motorcycle engine.
It does say though, if you are re-using the old cover bolts to also use non-permenant thread locker, ie. blue Locktite.
New bolts do not need the Locktite.
(They must already be treated with some sort of thread locker.)
I torqed to 69 in. lbs. on the left side covers. You might ought to go and check on Roaches engine rebilt videos for torqe specs.
1 - 6 of 6 Posts
