1 - 2 of 2 Posts
1999 kawasaki vulcan 750
Discussion Starter · #1 ·
Hi I'm changing my clutch handle assembly on my 1999 vulcan 750 and got a aftermarket clutch handle and mount. When I unplugged my clutch safety switch I noticed it was a 3 wire my aftermarket is a 2 wire. According to the wiring manual in my Clymer B/Y and Y/G is pulled in, G and Y/G is released. If I wire B/Y and Y/G to my 2 wire clutch safety switch will it work as you have to pull the clutch to start? Also I noticed the G connects to the neutral indicator light, is that no longer going to work or will it effect it at all?
Discussion Starter · #4 ·
Thanks for the info thorn. That’s the same reason I’m changing both my clutch and brake master kostamos my clutch has a slight bend and my master is shot. So I just wanted to change them both to be consistent and help with my slight modernation project I’m doing with my 750.
1 - 2 of 2 Posts
