1 - 4 of 4 Posts
Discussion Starter · #1 ·
My bike broke down and has been sitting a good 2 months, fast forward to today and there is no tension in the clutch return, I've heard about roatating the bevel in more than a few posts, given that the clutch was fine before it broke down and I havent touched it besides disconnecting the line, would there be any other reason as to why there is no tension before i dive into a good chunk of the manuel?
Three or so items can cause that, depending on what you're seeing.
Broken or stuck rack and pinion in the bevel gear case
Broken clutch basket or clutch stack binding
Stuck clutch pushrod
Cable binding
Does the cable and lower lever move freely if you pull it in and out by hand?
Discussion Starter · #3 ·
Cable binding
It moves freely with ease (bevel) but it was working fine before, it had broken down initially due to hella dirty carbs but I got that out of the way. Before it broke down, it was absolutely fine, if anything running a bit rich. But even then, it had only been sitting for less than 2 months and I put fresh oil in before it went away for storage until I could start working on it again which I am. I read a lot of reading and someone says to open the cover that looks like it could be opened with a quarter and push that pin in until it stops, then reset of bevel to align it with the case or something. Any other input before I get down and dirty?
Did you notice anything the first time you pulled the clutch lever?
If the lever on the bevel case moves freely, something is definitely stuck or broken.
1 - 4 of 4 Posts
