Resurrecting this thread because I'm gonna be doing this this summer at some point. Whenever the leak gets annoying enough to.
I have the gasket and found a vaguely relevant page in the manual that at least says what bolts get locktite. And I can look up the torque values.
I guess I'm just asking is there anything I should keep in mind as someone who hasn't done this exact thing before? My mind is blown that I'll be removing a section of the frame.
edit: Oh yeah, do I have to drain the coolant?
Shouldn't be any Loctite on those bolts. Edit.. correction, there's one bolt shown that gets either permanent thread locker, or sealant, manual shows both, thread locker in the text and sealant in the picture. (Marked A)
Manual also shows two o-rings on each end of the coolant pipe, the orings are supposed to be at the ends of the pipe, and don't apply grease.
You do need to drain the coolant, and the manual says drain the oil but if you have the bike on the side stand it shouldn't lose any oil.
Good idea to put penetrating oil on the exhaust bolts after wire brushing the threads, before removal.
The frame section isn't bad to deal with. Positive that I removed the footpeg and brake pedal, but manual doesn't show that.
There's a link to download a manual in my signature.
