1 - 6 of 6 Posts
so i got the kit hooked it up to the right plug hole and when i tested it the front brake lights up but when i test the rear brake nothing happens did i do something wrong :( its the right hole looking at the back of the bike
any help would be wonderful
Hmmm.... never knew we had a front brake light. :rolleyes:
:confused::confused::confused: ? Oh yeah ,I almost forgot. I am going to throw out an X2 ^
Adjust the screw tension on the rear light switch. If that doesn't work, the switch might be bad, disconnect and test continuity.
Did the brake lights work with both the front brake lever and rear brake pedal before you installed the Clear Alternatives kit?
1 - 6 of 6 Posts
