1 - 4 of 4 Posts
· Premium Member
Discussion Starter · #1 ·
When I first got my Vulcan in 2020, I noticed the previous owner had some electrical tape on this tubing here, right behind the right-side air box.
Fuel tank Wheel Automotive fuel system Motor vehicle Automotive tire
I never really thought twice about it until recently; I was performing a full visual check over my bike and found that the tubing was pressed up against the air box quite snuggly...to the point where the engine vibrations + heat gouged out a small amount from the tubing.
Fluid Thigh Human leg Automotive wheel system Tints and shades
Vehicle Hood Automotive tire Tire Motor vehicle
So I replaced the electrical tape and also used my Dremel to shave away a small portion from the rear of the air box to prevent this from happening again.
Gas Auto part Fixture Plumbing Metal
Probably not a super major issue...but as these bikes age I wanted to share something I went thru to share some common struggles & learnings. Cheers!
· Super Moderator
Glad you posted this. An ounce of prevention and all that...
Now that I've seen your post and am aware of the issue, I may do the same thing you did. Gotta love the Dremel!
I suppose an alternative could be to take a bit of rubber tubing, cut a slit up the side and just fit it over the plastic, if one doesn't have a cutting tool, or just doesn't want to alter the airbox.
Good catch!
· Registered
My '89 had that issue and I did the same fix. Good to post this though!
  • Like
Reactions: Vulcan_Frank_750
1 - 4 of 4 Posts
