1 - 2 of 2 Posts
Just as an FYI, I went to a U-Pull yard this weekend. Turns out the older Volvos and most Mercedes tend to have 7mm copper core ignitions wires. I pulled one for $5 for the project bike. If you cut off the ends of the wires they look pretty good internally.
It's a good option for getting cheap wire for a project bike. I also got a relay (ignition coil mod) an inline fuse holder, a radiator hose and a handful of clamps. Total was $7.
I had 8mm from a pull and cut one down to fit aS a teSt. Worked better than original. plug color waS Slightly tanner than from Stock wire.
DT
1 - 2 of 2 Posts
