Thought I would share my research on the rebuild kits for those twin Keihin CVK 34's.
EDIT: Notes on actual rebuild process have been added.
Online you can find many kits advertised for $22 or so however they are usually missing crucial items, and the machining of the brass may not be as precise. Don't scrimp on these precision parts which are the heart of your fuel system.
The CVKs have these parts which are replaceable.
I call the Drain the Jet Chamber, sounds much better and is more descriptive, no?
The Choke Plunger is also known as the Starter Plunger.
Most people in the industry call the Coasting Enricher the Air Cutoff Valve.
Here is the list of must have parts:
Here is the list of parts to replace as needed:
Rarely need to replace:
Available Kits:
All Balls Racing rebuild kit $48 online has float & jet chamber gaskets, pilot screw with spring and washer and o-ring, jet needle, main jet, pilot jet, float needle, enricher (air-cutoff) chamber and passage o-rings, and replacement screws for float chamber, jet chamber and coasting enricher. Missing choke plunger & enricher air cutoff diaphragms.
EDIT: It is also missing the Main Jet Holder, which is labelled Needle Jet Holder in the Service Manual. On Amazon their ad says the Needle Jet Holder is "pressed in" which is true. Normally the Needle Jet Holder has the Main Jet screwed into the bottom, and the Jet Needle fits directly down into it. On these CVKs the Main Jet has its own holder "F" which unscrews. I believe lots of people call it the "Emulsifier Tube", and it routes through an internal passage to the actual Needle Jet Holder. Only the Niche Cycle Supply kit includes this "Main Jet Holder".
Niche Cycle Supply has an excellent $39 kit that includes gaskets for float and jet chambers, jet needle, choke plunger, float needle, pilot screw with spring and washer and o-ring, needle jet holder (actually the main jet holder), idle adjustment screw (oddly...not sure on this usage, comments welcomed!), pilot jet and main jet. Missing screws for float and jet chamber and coasting enricher, enricher o-ring and diaphragm.
Chinese version of the K&L kit 18-9341 $22 eBay includes float chamber gasket, float needle, main jet, jet needle, pilot screw with spring and washer and o-ring, float chamber screws, enricher o-ring, jet chamber screws and jet chamber gasket. Missing pilot jet, needle jet holder (main jet holder), enricher diaphragm, screws for jet chamber and coasting enricher!
Japanese K&L rebuild kit $50 from Dennis Kirk includes gaskets for float and jet chambers, pilot screw with washer and o-ring (but no spring!), float needle, choke plunger cover (oddly!), pilot jet, and float chamber screws. Missing needle jet holder (main jet holder), jet needle, main jet, pilot screw spring, enricher o-ring, enricher diaphragm, screws for jet chamber and coasting enricher! (hard to believe it is missing all those parts, but I have verified that this is the case).
Hope this helps you with all those detailed parts, and your comments are welcomed!
- Main Jet #132
- Jet Needle (N53A front and N53B rear. Be very careful not to order qty 2 of a single rebuild kit, as you would then not get the different jet needles!)
- Needle Jet Holder "F" (While the Service Manual labels it the Needle Jet Holder, it is technically the Main Jet Holder. The actual Needle Jet Holder is pressed into the bottom of the slide bore).
- Pilot Jet #38 (also called Slow Jet)
- Pilot Screw with spring, washer and o-ring (often called Pilot Air Screw, but on the CVKs it is on the fuel side, so I believe it should be called Pilot Fuel Mixture Screw).
- Float needle
- Float chamber O-ring
- Jet chamber O-ring
- Coasting Enricher (aka Air Cutoff Valve) O-ring
- Choke plunger (also called Starter) with spring, seat and cap
- Coasting Enricher diaphragm aka Air Cutoff Valve
- Screws for Float chamber
- Screws for Jet chamber
- Screws for Coasting Enricher
- Screws for Vacuum slide
- Float
- Jet chamber drain plug
- Vacuum slide diaphragm, spring and seat
- Coasting Enricher spring
Available Kits:
