First the good news: My project bike is nearly 100%. Started up tonight for first time since I became the owner, and I went for a 25 mile test (joy) ride towards Santa Cruz, and she is sweeeeet!!!
But....I've done many brake jobs before, rebuilt master cylinders and the whole she-bang, but never ran up against such a stubborn one that is on my Vulcan.
Went through all the excellent forum posts and I'm out of tricks and patience.
First starting with Master Cylinder (MC). Was completely cleaned with isopropyl, compressed air, then BrakeCrafters rebuild kit and sparingly used RRG (red rubber grease). Bench tested it with single hose connected to the right caliper, which was also rebuilt. Felt weird, would not pump up. But using the thumb test, it felt fine. The local dealer mechanic charged me $60 to tell me it was fine too,
Replaced pitted piston in left caliper and replaced both the fluid and dust seals.
Used Mity-Vac to draw fluid thru both calipers, several times. Did the regular brake bleed method after that.
Never got any firm brake lever.
Tried a trick from another Vulcaner: Went to CVS and got a syringe, connected it to left brake bleeder with a hose, but when I opened the bleeder it pushed fluid out into the hose and could not force any more in.. so it seemed to have pressure there.
The only thing i noticed is that when I used the Mity-Vac on the left caliper with 15psi vacuum, and opened the bleeder, I got a solid stream of fluid into the bleeder hose.
On the right caliper, I got tons of bubbles. Always. So is the problem inside the right caliper? It was rebuilt the same as the left, and the seals and piston seemed just great on the bench. It is so simple, what could go wrong?
So I am losing sleep over this and can't bear the thought of bailing out and spending $120/hour at the local dealer.
Does anyone have any ideas how to locate and fix this problem before I throw in the towel (and checkbook)?
