1 - 3 of 3 Posts
I gone replace my front break lines with russel steel braided lines. I need to find out what size banjo fitting I need. also if they are the same size though hole system. The one thinking of buying is russel 3/8″ (10mm) banjo bolts that connects to into AN3 brake lines. Is this right size?
I also need to replace throttle wires and clutch wire to shorter ones.
Since I have change the handlebars on the bike. I probably need about 6 inches shorter on both. Any suggestion to find anything like that?
Any help would be great full
I’ll let you know here in about a week, I’m actually upsizing my handlebars so I’ll need a new brake line. I think it’s 10mm and I’m gonna purchase one that I can return anyways if it doesn’t work out. As far as downsizing, you won’t need to get shorter cables, there will just be excess slack but nothing unmanageable.
1 - 3 of 3 Posts
