1 - 7 of 7 Posts
please help im lost as to what is wrong with it i can go out and fire my bike up and let it run for any length of time then turn around and kill it and it refuses to fire back up again i'm wondering if the coils are bad and once the bike has started they get warm and dont want to work or is the bike like a car and has a crankshaft position sensor and just only wants to start when the crank is in a certain position i just swapped to a gel battery thinking it was a battery issue but that didnt do anything to fix the problem i really need help here thanks
Member? ... check.
Four things I can suggest to help with hard starting on our bikes. (besides well charged gel battery)
1. Get iridium spark plugs - part# NGK DPR7EIX-9
2. Research and do the ignition pickup coil gap adjustment.
3. Use your key switch to turn your bike off.
4. Clean battery(-) to frame and engine grounding points. Also clean battery(+) feed to starter.
I did/do them all. Bike starts immediately; hot, cold, everywhere in between.
i've been looking for the post you are talking about but having no luck finding it can you post the link to it or tell me which section to find it under thanks
Adjustment of pick up coils.
Remove the 3 phillips head screws on the left side. This will allow you to remove the pick up coil cover. You will need to place something under the bike to catch the oil although oil loss will be minimal. A rag was enough for me. Once the screws are removed, the cover should either come right off or you may need to pull on it. Mine was on pretty good and I had to physically pull on it to get it loose. The three screws and the cover all have separate o-rings. Once the cover is off, you will see the two pick up coils mounted to the stator cover inside two holes. They are mounted at roughly the 9:00 and 11:00 o'clock positions. Behind the stator cover, there is a rotor. You may need to rotate the rotor using a socket wrench on the shaft bolt in the center to align the small "plate" on the rotor with one of the pick up coils so that you can measure the clearance. Once you have measured one, rotate the rotor again so that you can measure the other. Gary recommends .020 clearance. Mine were about .030 or more. To adjust the clearance, remove the two screws which secure the pick up coils to the stator cover. You will most likely need to slightly elongate or slot the holes in the "ears" of the pick up coil mounting brackets. Gary indicates that a chain saw file works well for this but I used a rotary tool with a small grinding wheel on it. You will also see that there are 3 small protrusions coming out of the stator cover that each of the mounting
"ears" of the pick up coils fit into for proper placement from the factory. You will most likely have to knock the one closest to the center off to be able to make the necessary adjustment. A sharp chisel works well for this although you may want to cover the holes in the stator cover with something to prevent the little piece from falling inside the engine. Once the protrusions are knocked off and the holes are elongated, it is time to put the pick up coils back on. Set them back in their holes and start the screws. Place your .020" feeler gauge between the coil and the rotor "plate" and tighten the screws. Once you are satisfied with the clearance, tighten down the screws and do the same with the other coil. Gary recommends that you use both an impact screw driver and lock tite on the screws. I don't have an impact driver but I did use lock tite. Once both are set, put everything back together and test it out. I don't have a digital camera or I would have taken and posted some pics but you can look through the pictures in the Clymer's manual to get an idea of what I am talking about. In my manual (I assume they are all pretty much the same) the pictures on pages 296 to 302 should give you an idea of what I am talking about.
what kind of battery you have AGM?
You will also see that there are 3 small protrusions coming out of the stator cover that each of the mounting "ears" of the pick up coils fit into for proper placement from the factory. You will most likely have to knock the one closest to the center off to be able to make the necessary adjustment. A sharp chisel works well for this although you may want to cover the holes in the stator cover with something to prevent the little piece from falling inside the engine.
I saw one modification suggested for this procedure in another thread last week. Instead of knocking the protrusion off the engine case, you can file a relief slot in the pick-up mount to fit around the protrusion.
Hope this helps.
1 - 7 of 7 Posts
