1 - 18 of 18 Posts
I've been reading with great interest Hizzo3's messages regarding both his Frankenstator mod and his bigger battery mod. I have a few questions regarding the bigger battery install; unfortunately Hizzo3 hasn't been on here lately for me to ask him directly. I don't know if anyone else on here has installed a bigger battery (read larger capacity battery).
I'm wondering if I can just go ahead and install a larger capacity 12v battery with no problem, without having made any modifications to the stator ? I don't know if Hizzo3 added the larger battery in order to accomodate his Frankenstator's higher output.
If I can just add the larger capacity 12v battery then would I still be able to use the same Battery-Tender charger that I use now with my stock wet-cell ?
Thanks.
You could have the worlds largest stator, but the R/R is only going to put so much into the battery, so I don't think stator size would have alot to do with it.
I'm not really sure how the R/R works..... off of Amps, or Volts. That, to me, would be the only issue. Would a stock R/R put more Amps into a larger battery? Same with the Battery Tender.
But then again, I'm a machinist, not an electrical engineer, so I could have my thinking completely backwards ? :confused: ?
Battery capacity is rated in Amp / Hrs. A larger capacity battery is like getting a larger bucket. It "holds more" and hence can supply more at a given rate of discharge. Conversely, it take longer to fill back up to full, i.e. fully recharge. I am not up to speed on the charging system (yet) and am not sure if it would be equivalent to an alternator or a generator set. [UPDATE - 13AUG 07 - We have an alternator with a fixed field (permanent magnent rotor). The stator / perm magnet rotor generates a 3 phase AC (alternating current) voltage that is rectified by the diode rectifier bridge in the R/R.]
I have an on going interest, I want to add a Big Pair of driving lights. When I turn on my front lights, I want like it to look like I am working for Speilburg FX :) and that requires lots of Amps. Power (Watts) =I (Amps) X E (Volts) . 55W+55W = 110W; 110W / 12Volts = 9.2 Amps of additional load. A 10 Amp/Hr battery alone would only run this load for about an hour. After that the alternator set would have to handle this load, plus the standard system load.
Back on track, The alternator set is a constant voltage charging device. The Regulator / Rectifier (R/R) should maintain a maximum voltage at RPM greater than the battery voltage to the battery to charge and in effect, at that max voltage, regulate the nominal amount of current (amps) out of the bikes stator (alternator) to the system. The system, being the load, will include the battery, lights, etc. A larger capacity battery is a larger load on the alternator set, depending on its charge state. If it is fully charged, and there is minimal load on the system, the battery will greatly assist the alternator. BUT, if the battery is heavily discharged, it posses a threat of being a large load. I do not know what the "continuous current" capacity of it is, but it IS limited by the stator and the ability of the R/R to maintain this output without burning up itself or the stator windings / brushes as a result of too much load. And therein lies the rub.
The Frankenstator mod, if it increases the amperage output, will merely charge up a battery faster than the standard stator, and source more current to the system, as it has greater current output capacity. It will not damage anything unless the R/R has failed.
Addressing the Tender, in all likelihood it is a constant current source and it will only output say 1 amp/hr. Simply stated, a 7 amp/hr battery will take 7 hrs to fully charge, a 10 amp/hr battery will take 10 hrs to charge, etc. Using it should maintain the battery in a fully charged state. The limiting factors being the output rating, the capacity of the battery, and how much time you have to let it charge.
I would appreciate all leads and links to additional technical information regarding our electrical system.
Light On Dude!
Flash
Discussion Starter #5 (Edited)
I'm so frustrated...
Its just that I'm so pissed off at this bike's electrical/charge system. I know I'm not the only one and I also know that its an old problem, ie its a recurring theme on this board.
I'm finding I have to put the battery on my Battery-Tender about every 3days. Yeah, I do alot of city driving and it HAS been hot but come on! This is ridiculous.
The other night I conducted an experiment: I went for a long drive. Before taking off my battery read 12.51V. I rode for two hours at a constant 100-120km/h, 4500-5000rpm, all highway riding. At the end of the trip I took another reading: 12.65V. It was cool and the fan didn't really bogg the battery down.
I stoped for about 1 hour. Then I rode some more as before but for about 15minutes. I took another reading: 12.69V.
The other day my buddy, who has a Marauder 800, and I went riding around town all day. We got stuck In traffic a great deal and it was HOT. My fan was on constantly. It was stop-and-go for a great deal of the day. At the end of the day my battery was having a rough time of it, I had to pull out the headlight fuse in order to start the bike. His bike kept on going and going just like the energizer bunny. What the f!!k !?
I don't think this is normal. And I replaced bothe my R/R and the Stator about 3 weeks ago. I tested the charging system according to that electrosport flowchart and it checked out okay.
So I'm thinking maybe a larger capacity battery would allow me more time between Battery-Tender sessions, you know what I mean ?
I love this bike but I'm not feeling any love back, man. This is NOT a beautiful relationship.
Now what
The big problem is the bike was designed for cruising rather than stop and go. Not very comforting, I know. You might consider installing a switch so you can turn off the headlight when you're in the stop and go traffic, that would help a lot. Another good thing would be to get the LED board from Clear Alternatives http://tinyurl.com/2gov8p . I've noticed that my LED voltmeter hardly flickers when I put the brake light on now. With the old lamps it would dip 1/2 volt. A bigger battery would help keep you going longer in the stop and go, but the question is whether you could ride far enough to recharge it before you stopped the bike for the day. Putting the bike on a battery tender isn't quite so painful if you use Anderson Powerpoles for the connectors, http://tinyurl.com/2cbdv7 . I have a pair attached to some zip cord that runs to the battery terminals and another pair on the battery tender. And another pair that go to the driving lights. When I'm parked at home, the battery is hooked up to the tender, on the road I hook up the driving lights. Pretty painless and the beauty of the design is there is never any exposed conductors to short out. Here's a good articl on them http://tinyurl.com/w2j4f
Lebanon, NJ
Damn, I haven't experienced that with my 2000 I have a Big Crank: http://www.batterymart.com/merchant2/merchant.mvc?
and use a Battery Tender Plus: http://www.batterymart.com/merchant2/merchant.mvc?
The battery tender came with one Clamp Harness and one Lug Harness which I use after every ride to bring the battery back up to full charge. Never has taken more that 30 min. though. When it's fully charged, I disconnect untill next ride.
I don't have a volt meter nor have ever checked any voltages or any such electrical. But I swear by that AGM battery.
Discussion Starter #8
yeah...oh well
I forgot to mention I also have the new Clear Alternatives LED tail/brake light. It has made a huge difference. Charging up my battery using the Battery-Tender is not a painful process for me because like you I also have the extra plug attached to the battery. I have the "socket" tucked neatly into the little space beside the coolant tank.
Its the fact that I find myself needing to charge my battery at all that gets me. The bike should do it, just like my buddy's Marauder 800. If I need to charge my bike every three days then I might as well get an electric scooter and save on the gas.
I've thought about adding a headlight switch but I'm a bit reluctant because of legal/insurance issues should I get into an accident. In Ontario (I don't know about other parts of Canada) its illegal to ride without the headlight on day and night, for one thing.
Have you checked for the possiblity of a current draw (short) somewhere, while the bike is shut off? Sounds like there's something discharging the battery that shouldn't be.
This was a method for checking for a current draw from the Vulcan Verses...
Vulcan Verses said:
Electrical shorts are usually due to a pinched wire where the crushed insulation of a "hot" (positive) lead is touching the metal frame components and draining off the battery, even when the bike is turned off. It's not enough drain-off to overheat and burn the fuse out, though...Typical crushed-wire points are: under the seat, under the gastank and behind the headlight. You can test for battery drain, even with the bike not running. Hook up a multimeter (analog or digital) that has at least 5 amps of DC Current-measuring capability (most do). Be sure to hook-up the leads to the multimeter properly--most Analog (older type) Multimeters require you to move the red lead to a special jack in the panel. Then with the battery NEGATIVE lead disconnected, touch the red probe of the multimeter to the battery harness wire and the black lead of the multimeter probe to the negative lead of the battery ("in series")--battery still disconnected from the harness--. IF you have any measurement of current at all and the needle moves, either something has been left turned on or you have an electrical short. Finding it is a patient process of elimination. Try pulling one fuse at a time from the junction box or wherever else you have installed aftermarket fuses and watch the meter to see if the current drops to zero. If that doesn't reveal the problem circuit, try pulling each wiring harness *connector* from components around the bike--start at junction box, then ignition module, etc. Sooner or later you'll discover what cicuit/where the short is and then you can focus on that area of the electrical system.
Discussion Starter #10
anyone in Canada been able to source a MF battery ?
I haven't done that specific test, no but I have been keeping my eye on the electrical system ever since I replaced my r/r and stator.
After I tuck my bike in for the day I take a reading across the battery terminals. Next morning before I ride I take another reading across the terminals. Same numbers come up; I conclude there is nothing draining the battery.
Its a **** wet cell battery. I've been searching for a MF battery here in Toronto, where I live, but for some reason I haven't been able to find one. Both Canadian Tire and my favourite motorcycle super-stores have none in stock.
Which capacity MF battery would you guys recommend: 12AH, 14AH, 18AH ?
Thanks
I know how you feel,I to want to add lighting I have a ricks stator and I can ride in town all day,BUT! I have made many changes to the bike .But I'm gun shy at idle 900 rpm I just barley keep the bat up but as soon as I move I have more than I need.I think I might try the 18ah after reading your responses. I have a 14ah
Now what
Thanks
Since the bike runs off the battery in that stop and go traffic, I'd say the bigger the better.
When I checked my volts I found my stator was charging at about 1300 Rpm's.
So,when im in that stop and go traffic I simply reach done and turn my idle screw up to 1300 rpm. Have had no problems.
You can gain some extra battery time by installing a headlight modulator (if it is legal in Canada) - it pulses the headlight which results in a lower electrical drain. Bulldog swears his modulator gave him a bunch of extra riding time when his stator when out.
ROUND 2:
While replacing my exhaust stack crush gaskets, I got into inspecting my electrical system this past weekend as a side track. It turned into a tar-baby. http://en.wikipedia.org/wiki/Tar_baby
Of the three stator lead connectors, I noticed that one had been, is being, severely over heated as evidenced by the clear tubing being burned black and the male bullet connector being a flat, copper color instead of shiny brass compared to a known good connector. A second was on the way, but was "only" brown with same bullet connector heating issues. The third was "normal". As has been stated throughout the forum, IT IS CRITICAL THAT ELECTRICAL CONNECTIONS BE CLEAN and BRIGHT, not only dry. More so with the stator and R/R connections. After ensuring I had adequate slack in the leads, I replaced the the connectors, male and female with some waterproof connectors I found at my local Advanced auto parts (Dorman P# 85268 and 85269). OReilly didn't have them. I repacked them with Connector Dielectric grease. (I found out there is both Plug Boot dielectric and Connector dielectric grease out there. The Plug Boot grease is much thicker and more difficult to get reliabily into small spaces.) While doing so, I began to wonder what caused the "unbalanced" overheating problem. Went looking for more evidence.
Went to the R/R. There I found, where apparently in the past the battery boiled over and spilled, electrolyte down over the 6 pin connector that plugs into the R/R. The connector housing was eaten up, allowing the top left spade connector (one of the three from the stator) to possibly vibrate loose. The connector housing will have to be replaced. I disconnected the connector and ensured that the actual spade type connectors were still serviceable. They were. I still need to get in and clean them better yet.
I broke out my Fluke digital volt meter (DVM) and rang out the stator (yellow wires). Everything read as expected there. i.e. 0.3 ohms wire to wire; open, any wire to ground (chassis). With the stator wires disconnected, I then rang out the top three connections into the R/R (this would be the rectifier bridge) expecting to see some standard diode bridge front / back readings. Got some unexpected readings there on one. I then connected everything back together and started her up. Took some AC voltage readings from each of the stator connectors to ground and noticed the lead that had the odd resistance check also had odd voltage reading i.e 5VAC as opposed to 12.5VAC as on the other two. I then checked my charging voltage at the battery and found that I had 14.5VDC, low idle or 4K RPM. At that point it was time to get back to the original stack gasket job and ride 'em out. So I did.
All of this has a direct bearing on our electrical capacity. All three legs must be sourcing properly. In that bad connections leads to resistance, resistance leads to voltage drop and heat as current passes through it, which leads to more resistance, etc. it becomes a runaway failure that gets worse when the current load demand increases. If it is unbalanced, it places an undue load on the other stator windings, not to mention it depletes the overall ability of the alternator to properly function.
I still do not have any definitive answer as to what caused the "unbalanced" overheating connector problem. I am working it though, and have some suspects.
I will be more specific with readings and pin positions with hopes that someone else might corroborate my findings or I can find another Vulcan to check out. The check out is painless and non-destructive. Any readers in the Clodine / Houston Texas area? Any body else have a DVM?
"Please don't throw me into the briar patch." says Br'er Rabbit...
Flash
Ditto Hyper....
Normally a battery should be able sit for months without discharging itself. If there is a drain on the battery with key off, this is a problem that must be remedied before you put a new one in it.
It may be that your battery is crapped out. Take it down and get it "Load Tested", not just metered. Having to run a tender to keep it charged after several days (weeks!!!) bodes ill....
Flash
Discussion Starter #17 (Edited)
I'm wrong...again
Okay, I stand corrected. This is not a good indicator for current draw. I thought any change in amperes would be reflected in voltage but this is not necessarily so. Thinking in terms of battery capacity now: If a battery can be 12v 10AH, 12v 12AH, 12v 18AH, and so forth then something can be reducing my battery capacity to, say, 9AH but still show 12V.
I think I get it now...hopefully. Yeah, I better use that test you quoted from the Vulcan verses, Hyperbuzzin.
Thanks.
P.S. Quick question: does a battery have to be fully charged in order to have it correctly load tested ?
EDIT: Okay, I've just done that current drain test and am happy to report there is nothing draining the battery. Performed the test three separate times just to make sure.
Battery's next. I finally sourced a Yuasa YTX14AHL-BS mf battery. Will get it in 2-3 days, then I'll have the current battery load tested just to try to pinpoint the problem.
I don't know if this wall I'm hitting is the electrical weakness of the VN750 or a problem with one of the components. I have no frame of reference to compare with, especially seeing as this is the first summer I've had with it. I got it last October when the temperatures were alot lower. Gotta keep drilling down, I guess.
Gold Star for ktullu. As you surmise, in general terms, as long as there is adequate capacity, the voltage reading doesn't reveal much, considered by itself. Make sure your battery is fully charged before load testing. I have read of "voltmeter" kits for the VN, does anyone know if anyone makes an ammeter kit?
I googled "lead acid battery discharge curves" a found some germaine and interesting information regarding our quandary. Though I did not find the word motorcycle, the technical detail is valid. And remember, information is like eating fish, pick out what you can eat and ya' gotta' watch out for the bones.
http://www.vonwentzel.net/Battery/00.Glossary/
http://www.batteryuniversity.com/index.htm
make good reads. Keep in mind we are addressing lead acid VRLA / AGM / Gel types.
Pay close attention to the effects of overcharging and conversely not "discharging" adequately before recharging... This causes me to think and rethink the use / reason for battery tenders. I have yet to pull my battery, and the fellow from whom I bought the bike has no idea what kind it is. I do know I have had (knock on wood) no problems with it.
Round 3:
I made clean, bright, and tight the 6 pin connector into the R/R. Drove her around a bit to warm 'er up.
ALL "odd readings" changed. I am no longer reading any resistance (ohms) across the rectifier bridge pins. I am now reading 8.2 VAC on each of the three yellow leads with 14.5VDC on battery at 4K RPM and 13.5VDC at idle. The replaced stator lead bullet connectors show no sign of overload.
I too have no frame of reference for T'Pol, but I will continue to collect data and post "pertinent" findings. I am going to break out the ammeter and do some load testing next. Ignorance can be treated...:smiley_th
Keep the Faith.
:rockon:
More to come...
Flash!
1 - 18 of 18 Posts
