1 - 10 of 10 Posts
Well I just finished reading all through the verses and can't find out how long others have had their AGM batteries last. Also, has anyone used, or know if you can use a battery load tester for auto batteries on a bike battery? My gas mat battery left me stranded a while back and it was about 3+ years old. I usually keep a tender on it if I am not riding everyday so I was surprised when it died. It takes a charge but shows weak on my HF load tester.
My son’s battery is coming up on probably 5 years and still cranks fine. But since I found out my AAA is not the correct coverage for motorcycles I don’t want him to be stranded like I was. Also I don’t see how any one “bump starts” these babies. I tried pushing it to the top of a parking lot and getting it going as fast as I could downhill but I guess I am just getting too old. As soon as I let the clutch out I just stopped. Maybe with some help, but not by myself. I miss the kick start of my H2.
There is no clear cut answer to your question. if you are comparing your AGM to your son's, are they both the same CCA and brand? The higher CCA batteries should last longer plus there are cheap AGM battery manufactures just like every thing else.
With smaller motorsport AGM batteries, 5 years is a good time to swap it out. If well maintained they could last longer, no doubt, but it's never fun to be stranded somewhere when a preemptive replacement could have taken care of it.
I've bump started the VN once. Took about 5 tries. The most important thing was to basically slam down onto the seat when letting off the clutch to give the most traction on the rear, otherwise she just locks up.
Where I live (SW florida), if you get 4 or 5 yrs out of any battery, your doing good, real good. the heat kills em.
also, bump starting is hard because if your in 1st, its hard to get the engine turning. can be done, but harder. also, unless the positive neutral system in the transmission is missing or defective, you cant get anything other than 1 or neutral when stopped
You can get past 1st and neutral; just roll the bike forward with the clutch puled in and shift.
I was in second or third when I bump started it, so definitely a good important piece to note. :rockon:
2000 VN 750 Senior Member
Installing a gauge to check on the battery charging and overall condition would be a good addition to any set up. Several members of this forum had done so and are constantly aware of any adverse conditions before they are a real problem leaving one stranded on the road side.
yea you can do that.. providing you can get it moving fast enough (mine wont shift until about 8 or so mph). but ya, once in 2nd, 3rd or 4th not a problem. Also, I have a fair amount of clutch drag on mine, its noticeably harder to push in 1st (with clutch pulled) than in neutral
Discussion Starter #8
Yeah I checked my old battery and it was only 190 CCA my son's and my new one (DieHard $109.00 out the door at Batteries and Bulbs with a 2 year warranty - ouch) are both 220 CCA. Both old ones are off brand (Extreme Magna Power and Extreme something?) both say made in USA one in Baltimore and one in Philadelphia. Both famous for their batteries:rockon:. I swapped my battery into his bike to see if there was a difference. There is. A BIG difference. I think that his battery may be fine for a while but the savings on the time the starter cranks is huge. Almost instant with the new one. Funny thing is that my bike started great right up until it didn't. For now we have both agreed that it may be time to get a new battery for his bike. I'm getting ready to do some other work on his (MCCT and marbles just to start. My older bike runs much better with those mods and what he doesn't know won't hurt him. (Kind of like having a wife :) Next is opening up his baffles a little. He originally wanted a set of V&H but now the cost just does not seem to make it worthwhile. These bikes have more than paid for themselves since we live in northern CA we can ride almost all year long.
One more thing, any opinions on the battery load tester? Right now I am waiting until tomorrow to bench test the voltage on my old battery. The battery tender brought it up to a charge in about 30 minutes. So I think it is just "taking" a surface charge.
I got five years from the West Co in my Vulcan. Got 6 years out of the stock Yusa AGM in my FJR. Only got 3 out of the stock Yusa AGM in my Bonnie...but think I let it go too long between charges.
I've seen them last 3-7 years from other members. You really need a "smart" charger for these.
1 - 10 of 10 Posts
