1 - 5 of 5 Posts
If anyone could help? I have an 86 Vulcan 750 with 29,000 miles on it, I'm not too mechanically inclined so you're talking with a rookie here. But after I seen what they were going to charge just to check it I said let me get some help and go for it myself. I bought her the end of last year and really haven't done much to her except the basics for a tune-up.
The problem is I start the bike and watch the voltage on the battery and she starts out with 12.7. When I start her within 10 minutes of idling she drops to 10.9 and dies out. I'll try to restart it and nothing she just clicks at me, so then I have to recharge the battery. I just replaced the battery with a Yuasa 14AHL-BS AGM battery in January, I already purchased a Clymer's manual, still trying to figure that out.
Any ideas what it could be? Any help would be greatly appreciated.
You have a charging system problem. Either a stator, rectifier/regulator, or both. Read up in the Vulcan Versus about how to troubleshoot this. (http://www.vn750.com/forum/forumdisplay.php?f=40)
Let us know what you find out or what questions you have.
Jon
X2 what 93VN750 posted.
Yep, agreed about the charging system problem, but 10 minutes? I'd say you also have a bad battery as well. There is quite a bit of information on here about how to check the charging system, but I don't remember it, because I've never needed to check mine. I hope it is not the stator, because that means pulling the engine. Jerry.
You should have a battery terminal voltage of ~14.5 vdc at 4 to 5,000 rpm. Check it and see what you get, then get back to us. Could be reg/rectifier or stator if voltage is lower than specified.
1 - 5 of 5 Posts
