1 - 9 of 9 Posts
I got a battery tender at Wal-Mart for around 20 bucks. And also the batt. I think the batt was about 80 bucks. It is the AGM batt.
romeobravo172
The Advanced Auto is the one I bought (etx15L) and seems to be holding up well. Paid $74.19 out the door. Batt tenders are relatively cheap, some less than $20. I have 2, one is a 2 amp, but prefer the 1.5.
I found a power pack for a cordless phone charger, output is 12v dc @ 750ma, same stats as a Battery Tender, it just doesn't have the circuitry to shut off at full charge. Put some alligator clips on it and have been using it on my tractor battery with a timer.
I was able to snag a new Battery Tender off Ebay for $1 + shipping, will use it on the bike.
a battery float charger is a low current output made to just keep the battery from loosing its juice over the winter.
http://www.harborfreight.com/automatic-battery-float-charger-42292.html
A battery tender usually has a higher current output to bring the battery to peak then it will drop down to a lower current 'float' mode.
I have never tended my batteries and never had a problem, I charge them now and again with a 10A/2A charger
good luck
kenny
I bought the same two days ago.
http://www.walmart.com/ip/Schumacher-Automotive-SpeedCharge-Battery-Maintainer-and-Charger/13005742
I did some research on it after the fact and there have been a number of complaints on it's dependability. The reviews are from Amazon.com. I did use it and it worked. The different lights on it seemed a little screwy. :motorcycl
1 - 9 of 9 Posts
