1 - 13 of 13 Posts
· Registered
Discussion Starter · #1 ·
I've had a 700 in my garage for several years with a blown balancer and cracked case. I've read several of the posts here concerning balancer issues, warnings about availability, and the PITA to replace them.
My Q is, how does the balancer work? What fails on them?
Some people say the bolt backs out?
Thanks,
D
· Super Moderator
2003 VN750
Thanks,
D
The bolt should never back out, it's left-handed threads and is supposed to get Loctite then torqued to (a bunch). Though there's been cases of the bolt coming out.
There's a damper that's weighted on both ends of the balance shaft. The spinning weight cancels out vibration.
What fails is the rubber composite bushings on left side damper gear. You can find chunks of the bushings in the oil screen as they begin to fall apart.
· Registered
Discussion Starter · #3 ·
I borrowed the pic from davionics post, thanks! Excellent detail.
Why the need for the bushings? You'd think it was a simple counter balance weight. Almost $100 for six.
@ Spockster - I researched some of your posts from 2016ish. How would the balancer work if it were welded solid without the bumpers?
Automotive tire Motor vehicle Locking hubs Wheel Vehicle brake
· 💀Administrator💀
Unfortunately, the older posts don't show the pics. 😞
I don't know jack squat about the balancer or the bushings, but if I were on a gameshow and had to guess, I'd say that it's because internal combustion engines are inherently inconsistent and unstable, thus requiring a certain variability in the balancer?
If I somehow got this right on accident, I fully expect a participation trophy.
· Super Moderator
2003 VN750
Welding it would probably increase harmonic vibration, but the damper weight would probably still provide some reduction in rotational vibration.
The bushings isolate the gear from the weight.
I've been trying to restore my pics when I find them missing, I'll see if I locate the posts. You might've seen the posts about me installing the damper gear out of phase... Wish I had a video, the vibration was unreal, supernatural even. ...or paranormal?
I always thought the bushings could be made from Delrin, or some other synthetic material.
Half the bushings are smooth on the outside edge and half are sawtooth, don't understand why they're different.
· Registered
Discussion Starter · #7 ·
I read your posts about Delrin. The OEM bushings are available now, but at a price. Even my 77 KZ has a balancer, I don't think my 77 XS does, never looked.
· Iron Butt Association Member
I will grant you one! :poop:
But I think you're right. The rotational speed of the engine varies quite a bit per rotation.
An engine only speeds up for 1/2 a rotation and spends 3/2s of a rotation slowing down.
Most of the slowdown happens on compression, just before it's 1/2 rotation of the power stroke.
Being a V-Twin, it's a little more steady than a single, but still lots of instantaneous changes in speed throughout each rotation.
The rubber provides some elasticity to this to smoothly reduce this rotational vibration.
Essentially, a harmonic balancer.
If you've ever taken apart the rear wheel assembly, there's a giant rubber piece inside that couples the rear drive to the wheel.
Part #92075 2005 Kawasaki VULCAN 750 (VN750-A21) Rear Wheel/Chain | Kawasaki Parts Warehouse
This reduces the rotational vibration/shock on the driveline. This also can help prolong tire life by not forcing harsh power pulses on it.
· FREEBIRDS MC CENTRAL NY
The
They are available again? Cool. Do you have a link or are you going to make a grumpy ole bastard search for them? Lol
  • Haha
Reactions: dirtrack650
· 💀Administrator💀
The
I will NOT have you using that word in this forum again! Do you understand me???
Nobody on this forum is "ole" or "old" as you so eloquently put it.
We are... ahem... "Well aged."
Nose Smile Head Eye Vertebrate
  • Like
1 - 13 of 13 Posts
