I just bought a 1986 VN750 two weeks ago. I'm still learning to ride, so I stalled out a few times Thursday. This may have something to do with the following problem:
Symptoms:
Stalled out, couldn't start engine again
Battery was dead
What I've done:
Recharged the battery to full
Tested it on a battery tester. Checked out fine.
Took her out for a ride, seemed OK. The previous owner installed a voltmeter and relocated the regulator/rectifier as detailed in other posts on this forum. The voltmeter is connected at the battery.
Voltmeter readings:
12.8-12.9 VDC bike & ignition off
~12.3 VDC ignition on, engine off
About the same when the engine is on, and idling
Revving the engine doesn't change the voltage reading. The only thing I found that changed the voltage measured was actually getting the bike going in a higher gear (>=3) and at an engine speed of about 3k RPM.
This is from memory, but I'll try to borrow a decent voltmeter and measure voltages directly.
Has anybody experienced anything similar, or have any suggestions on what I can do to troubleshoot further?
Symptoms:
Battery was dead
What I've done:
Voltmeter readings:
