1 - 1 of 1 Posts
vulcan lover/hater
I apologize for posting this same issue a second time, but when I got on the site this morning I had trouble finding my original post. OOPS!
Plus the thought had occurred to me that maybe a bad vacuum tube to the rear-cylinder carb might have the same effect on the back cylinder that a bad fuel-tap-diaphragm has on both carbs. Anyway, happy Resurrection day! Maybe I can resurrect this bike!
The bike worked perfectly last fall. After putting the tank back on and reconnecting everything like I have for the last ten years. the bike idles for ten seconds, then chugs to a stop with raw gas dripping from the joint in the tailpipe from the back cylinder. The back plugs are soaked.
Could I have bad gas or vacuum lines? Maybe the float is stuck--and I'll have to remove the carb?
1 - 1 of 1 Posts
