1 - 4 of 4 Posts
Anyone know the exact width of the Avon 110-90-19 front tire with running pressure...???
I would like to know if you have that info... Or if it is wider or narrower than a Dunlop 404 110 front...
Thanks, and have a good one....Old Dog...
Avon AM41 Venom 110/90-19
Tire Size: 110/90-19 Rim Diameter: 19
Position: Front Width: 119mm (4.7″)
Speed Rating: H - Rated up to 130 MPH Overall Diameter: 26.9″
Tread Depth: 5.2mm (13/64″) Rim Width: 2.15″-3.00″
Sold in Units: Each DOT Approved: Yes
Inch System: 3.75/4.00-19 Tire Construction: Bias Ply
Manufacturer Part Number: 2809612 Tire Width: 110/MN
Aspect Ratio: 90 Sidewall: Blackwall
Tube or Tubeless: Tubeless Load Rating: 62
Dunlop D404 110/90-19
Position: Front Width: 110mm
Speed Rating: H - Rated up to 130 MPH Manufacturer Part Number: 32NK-31
Overall Diameter: 26.56″ Tire Construction: Bias Ply
Tread Depth: 6/32″ Sold in Units: Each
DOT Approved: Yes Inch System: 3.50/4.00-19
Tire Width: 110/MN Aspect Ratio: 90
Sidewall: Blackwall Tube or Tubeless: Tubeless
Load Rating: 62
This help?
Load Rating: 62
This help?
Thanks CW-4, that is what I was afraid of, the Dunlop 404 will pass by my fender/fork bolts if I give it a good chug, but with the Avon I would have to remove the fender/bolts to install... It being Approx. 9mm/.36" .18" & .18" each side wider may even give me trouble on the fender after install...
I thought I remembered seeing somewhere that the Avon was wider...
Thanks, and have a good one...Old Dog...
Discussion Starter #4
Well it looks like the Metzler 110-90-19 is 112mm wide so that should work, and probably what I will go with... Thanks for the help...
1 - 4 of 4 Posts
