1 - 20 of 37 Posts
i found this fork conversion chart while lurking on streetfighter.com(yeah i know,but i am also playing with a 600 katana).andWolfie,the vn 800,900,and 1500 share common bearing sizes with the 750.i know you are looking for a wider front end;).the chart does not show stem length,only bearing sizes.All Balls Racing is a company that sells ball bearings.
http://www.allballsracing.com/index.php/forkconversion
Thanks bro...saved the link !...stems can be cut and rethreadded too if needed...long as a bearing swap aint needed, thats 3/4 the battle...
Unlucky Bastard
url removed
Pardon my ignorance. I'm still learning alot of things. Does that mean that a vn1500a front end should bolt up to a vn750 without alot of bs?
Discussion Starter #4 (Edited)
the chart shows the bearing sizes only.there may be a difference in stem height,but it should be close.i think someone on here did that conversoin,but am not sure.do you already have the vn1500 front end?if so,just try it.the worst that can happen is that you have to put the old front end back on
Someone here, forget who, has a 1500 front end...I think they only needed to do minor work...I need to get out to Pinwall in Ohio one day...they got lots of em for a decent buck...
front end
pressed middle stem out(after removing bearing)from original triple tree and press fit it into any front end u like thats how i did my upsidedown
This is also true...good thought... :smiley_th
As long as the new and old stems are the same diameter...
But thats the whole issue....to be able to use a wider tree in the same stem/neck...lol
I could get a new tree made, to fit my tubes, et al, but if I had the money for that, Id just get a different bike. Cutting/swapping a neck is an option, but again, not worth the cost. Mebbe I'll just get a custom stemmed springer made up....its what I want anyway.
We're talking direct or near direct fork and tree swaps....usually to accomodate a wider rim and tire.
dont get it?my forks are 15mm bigger kept triple tree they were one and just pressed in the middle spline so it fits my neck
We're not looking bigger, we're looking wider, i.e. different tree with same stem.
Because..........you cant put say a 17" wheel with a wide tire onto a VN. There's no room. Therefore the search for a wider front to accomodate. VN1500 seems to be the closest.
Discussion Starter #12
That is what I an gonna do for the springer on my '86
Discussion Starter #13
And if it is able to be a bolt on then it is even better.:smiley_th
I bought some 1500 classic forks,and looking at them they're shorter than my stock vn 750 forks. In consideration of the fact that I have a larger front wheel, diameter wise, than the classic. I can only think the frame and or trees are considerably different on the classic, Rake wise or head hieght.
the classic forks wont work as a direct bolt on, you needed to get a set of 1987-97 vn1500a forks. the stem is roughly 3/4" of an inch longer than ours, so you have to cut it down slightly and machine a spacer.. other than that its a a direct bolt on.
yes this changes the rake to almost 40 degrees if memory serves me right...
...always the option of longer upper tubes then though from Frank's....right ?...with spacers ?....uppers are what, 40 or 42mm ?...I dont remember....goin senile....we got what, 38's ?....ENs had 36's I think....
Id really like to put another wideglide front end on mine....my '53 one was sweet.....
I downloaded the one ya had up back when....I gotta wait for mid winter before I can do sumpin like this though....Pinwall in Ohio usually has a ton of 1500 front ends....
What Id really like, lol....is a wide, short springer....that wont happen though...buddy of mine has one for $350....Im just gonna go vn1500 so I can put on a fat front tire with smaller wheel....
That is pretty much what i want too... but i got an idea to build my own, using the vn1500 triple tree as my base.
Talk to me brother.....we're lookin the same thing pretty much methinks....tubes and lowers is nuthin....the tree is where it all starts....
....and not fer nuthin....but if you have a tree for say 39mm uppers (Honda I think), you can go one up to 40 real easy.....thats only 1/2mm all the way around....you can go up, but not so good to go down, then ya need shims, and thats halfazz....
Get a close enough Jap tree, and you can put StreetGlide uppers and lowers in....or whatever....but yeah, the tree is the main thing to get....after that, its easy.....toughest part really, is to find a "bolt on" neck....once thats done, rest can be fixed....I wouldnt think twice about millin out a 1/2 mm out of a tree....hell, all ya need is a round bastard if the trees aluminum...
1 - 20 of 37 Posts
