1 - 12 of 12 Posts
Yesterday my son was playing in the garage near the bike :loser1:
And ...
He has pushed a metal heater which was stocked on the wall close to the bike (small garage ! )
BUMP :hitanykey the nice and shiny tank has now a bump ! a strong one !!!
:BLAM: NOOOOOOOOOOOOOOOOOOOOOO!
85 VN 700
Ahh... Kids will be kids... When I bought my bike the previous owners kid had played with the idle adjust knob - and the bike wasn't happy (when I looked at the bike it was the first time it'd been started since summer).
Some people will be along shortly to suggest ways to get the bump outta your tank.
By "strong" do you mean a big one?
you can try using dry ice.....I tried on mine but had no luck, I think the tanks may be too thick for this to work, I have a dent on the roof of the car I am going to try it on (don't ever put a bed on top of a neon) just waiting for nice hot days for it to work best
If the dent remains, you'll come to think of it as a "cute" reminder of the days when your son was so little. Not to overstate the comparison, but we have two Great Pyrenees - and we have a couple pieces of nice-ish furniture that got chewed on (Zach also ate two remote controls before just putting some deep teeth marks in our current one). Now that they're older (Zach is old), we just look at the chair legs and chuckle. Everything has a history - the dent may become part of your bike's. :)
The tank is probably too thick and does not have enough surface area for the dry ice. Try finding a dent puller kit that consists of a nylon bridge, glue on threaded stud, and handwheel. They usually work somewhat on small dents that do not have pressure points (shallow dent without crease. If you have acrease or deep dent then chalk it up to a beauty mark or seek the help of a professional.
Yep, kids will be kids. Not sure about in France, but here in the States, some of those dent remover guys can do wonders.
There was a dent on my tank when I got it. Luckily it was on the top, a bit below the gas cap. I was able to cover it with a tank bib.
thats where mine is so forget the dry ice and try what rckmtn says.
I've been using the dry ice on a tank with a dent the size of a baseball. I now have it down to the size of a quarter and am still working on it.
Get the dry ice from your local grocery store for free (don't forget to take a cooler with you). They usually get it certain days of the week with their frozen deliverirs and just put it outside in the sun to disappear. Since mine was so big I have spent several days and hours on it due to it's location (several inches forward and to the left of the fuel cap on the curvature of the tank).
It will work but it usually takes many attempts ($ cost is nothing--just some of your time). Certain "light" dents will usually pop right out with one or two attempts, but these are usaully tiny hail damage like dents. Location of the dent also is a very significant factor as to how many attempts or "if" it will even pop out.
You need to hold the ice against the dent for several minutes. USE GLOVES!!!
You may want some ear plugs also, when the metal is very hot from sitting in the sun and you hold the ice over the dent it tends to "scream" very loudly. Make sure the ice is at least an inch larger than the diameter of the dent. You can use light pressure and move the ice very slowly around the area of the dent to widen it's effect. When the entire dent and an inch or so around the dent develop a light but visible "frost" remove the ice and wait. If it does not remove the dent keep trying it. My work in progress has been yeilding results but very slowly. The dent only comes up a little at a time, hardly visible at all. Very hot sunny days also help, make sure the dented side of the bike is facing the sun directly. Hope this helps.
I put my knee into the side of my tank when fell with the bike in the back yard. (Just learning to ride) I was a smooth dent with no paint damage. I was able to get the guy that comes to the car dealers to pull the dent. He went in through the filler hole and pushed it out from the inside. 97% effective and cost me $20.00
I've heard they are usually inexpensiive. I have a local Dent Wizzard near me, but they wanted 80 + $ to remove it and couldn't garuntee it would come out because of it's location. So I opted for the dry ice. If it works--it's just time invested, If not I'll use body filler to fill in the remainder of the dent before I paint it.
Discussion Starter #12
Hi !
Seems to be not possible to remove the dent to deep and too "hard" on the edge, ok I think i will fill the dent and repaint the tank completely. :hitanykey
When I said strong,not so big, but deep and stiff, I will take a picture when the sun will decide to come back ....:loser1:
1 - 12 of 12 Posts
