1 - 16 of 16 Posts
Hello all
Was gifted a set of 14 inch ape hangers. Having a bit of trouble finding cable kits to fit. Does anyone have any leads to where I may find or if there are kits from harley that will fit?
most kits I see are for harley, and or claims that won't fit vulcan bike.
Thanks Ant
probably will have to have custom cables made.I think Pro Motion makes longer custom cables
Remember, our stock bars are 7/8" diameter. The HD bars may be 1".
7/8 bars I have its the cables I was wondering about - the specific details within the cables and those little hook up tabs that fit the linkage areas.
After from what I see and am being told I may not be able to do this without extensive cost and such
My understanding with the 4 cables you need it would be a $200 project or so via MotionPro. Not cheap =/ Doable though, just ask for VN750 throttle/clutch/choke cables + X inches.
How tall can you go with the handlebars and keep the stock cables? I was looking at some 12" apes, but would definitely go down to 10" if that meant I didn't have to do new cables!
I had 10" z-bars on mine
From my understanding 12" apes you'll need new cables or have to find a clever way to reroute the stock ones. The clutch cable being the major problem and the wires for the electrics. A 10" bar would be a lot easier. (Amazing how just those few inches matter)
Good data point. Did the cables follow the bars? As in I might get away with 12" apes since its more of a straight shot up to the controls?
Thanks, Knifemaker. I'd much rather not have to do this by trial and error if I can avoid it ;) Is that personal experience talking or best guess (albeit a well qualified one!)?
So I was tinkering with my handlebars last night, and I found them to have a rise around 10". Unless I'm totally measuring wrong? I've got lots of slack in the cables currently (especially after rotating the bars to be more upright). Am I missing something?
measure from mounting point to highest point on the bars.that's your height.
Time I weigh in on this as I have 16" on my bike and had 12" before. With the 16" (and I assume 14") I had to order all new cables from Motion-Pro, the electrical was able to be spliced. The 12" bars I started my mod with, I only had to order a new brake line from Motion-Pro. These guys are great as they dealt with me so much about 12 years ago they still have all of the specs for our Vulcans....
Good Luck!
Stevie D.
Discussion Starter #16
I haven't tried yet to install. The quote i got was a zip code, that's not gonna happen. current bars are upright now and I lessened the pull back a few inches with heat bends. I will look into motion pro about the lines, and maybe add that to the re designing of the winter project.
Thanks guys
1 - 16 of 16 Posts
