Hi all!
As my project on making things work on my 2006 VN750 continues, I wanted to share with you this idea!
I am sure people have done this with that or with a different way, but I felt like sharing my thoughts and results.
So….while I was looking to find a luggage rack to fit the bike, I saw a few times this simple rack and a few other models.
looking for the original OEM product made me a little mad because not only it’s hard to find, but also it’s crazy overpriced…and slightly uglier…
I was thinking what if I can make cheap some brackets…and how? I had the choice of course to go pay someone to make (cut and weld) a custom rack but that would be way more expensive .
after a bit of thought, I bought that metal piece for making racks, some bolts and this luggage that I found on eBay, brand new for $32.
I measured the inside of our sissy bar and all the new ones were larger by at least 2-3 inches. So I bought this one that has inside diameter about 9-1/4. So if I had to add 1.5” on each side I could have this results.
So, I did this patent and it turned out actually a little better than I thought and with less than $50 total cost. It doesn’t look ugly and it’s solid.
You could use slightly thicker on the metal bracket’s thickness too, but this is great and can stand a lot of pounds! I just needed it for luggage bags etc either way.
I hope it helps!
I hope it helps!
